How to Make a 6-Foot Growth Chart on a 4-Foot CNC
Apr 20
Solving Real-World CNC Challenges with Smart Setup & Simple Techniques
One of the most exciting parts of owning a CNC isn’t just what it can do—it’s what you can figure out how to make it do.
In this project from the Johnsonville Woodworker, a simple request turned into a great example of problem-solving:
How do you cut a 6-foot growth chart on a 4-foot CNC?
Let’s break down how this project came together—and how you can apply the same approach on your own Onefinity CNC.
The Project: A Custom Growth Chart
The goal was straightforward:Create a clean, engraved wooden growth chart from a design file (sourced from Etsy), using a standard pine board.
  • Material: Clear pine board
  • Length: 6 feet
  • Tooling: 1/8" straight flute bit
  • Machine: 4-foot CNC
Simple—until you realize the board is longer than the machine’s cutting area.
The Challenge: Cutting Beyond Your Machine Size
This is a common situation for CNC owners. Your machine might be incredibly capable—but physical size limits still exist.
Instead of stopping there, this project used a tiling-style workflow:
👉 Cut one section👉 Reposition the board👉 Cut the second section perfectly aligned
This is exactly the kind of flexibility that makes CNC such a powerful tool for real-world projects.
Gen 2 Elite Series - Batch 6
From$2,437.00$2,195.00
Step 1: Rethinking Your Zero Point
Most users default to setting zero at the front-left corner of the material.
For this project, that wouldn’t work.
Instead:
  • Zero was set at the back of the machine
  • The first cut was run in reverse orientation
  • This allowed the second half to align when the board was flipped
This simple shift in thinking is what made the entire project possible.
Step 2: Using Alignment Pins for Repeatability
Consistency is everything when you’re repositioning material.
To ensure perfect alignment:
  • Pins were installed in the spoilboard
  • The board was indexed vertically along the Y-axis
  • Clamps were added to secure everything in place
This created a reliable reference system for both cuts.
Step 3: Air Cuts = Confidence
Before committing to the cut, an air test was run:
  • Bit raised ~1 inch above the material
  • Full toolpath simulated
  • Visual alignment confirmed
This step is often skipped—but it’s one of the easiest ways to prevent costly mistakes.
Step 4: Cut, Reposition, Repeat
After completing the first half:
  1. The board was removed
  2. Stops were repositioned
  3. The board was flipped
  4. Zero was reset using a touch probe
Another air test confirmed alignment before running the second cut.
Step 5: Clean Results with Simple Tooling
The project used a 1/8" straight flute bit, which worked well for detail—but came with one tradeoff:
  • Sawdust packed into the engraved grooves
A quick cleanup solved that easily, and the final result turned out clean and precise.
Step 6: Finishing Touches
To wrap things up:
  • Edges were softened with a round-over bit
  • The board was left unfinished so the customer could customize it
The final product?A clean, professional-looking growth chart—made on a machine technically “too small” for the job.
Apprentice Series - Batch 4
Why This Matters for CNC Owners
This project highlights something we emphasize all the time at Onefinity:
Your CNC is more capable than you think.
Even with a smaller machine like a Woodworker or Journeyman, you can:
  • Tackle oversized projects
  • Use tiling techniques for extended cuts
  • Build products with real commercial value
Turn Small Machines Into Big Opportunities
Projects like this aren’t just fun—they’re practical.
Growth charts, signs, furniture components, and long panels are all:
  • High-demand products
  • Easy to customize
  • Perfect for small business production
And the best part?You don’t need a massive industrial machine to do it.
This was a first-time technique for the creator—and it worked beautifully.
That’s what CNC is all about:
  • Trying new things
  • Solving problems
  • Expanding what your machine can do
If you’ve ever thought “my machine isn’t big enough for that”—this is your reminder:
👉 It probably is. You just need the right approach.
Build more. Learn more. Create without limits.
QCW with Heavy Duty Fixed Stand (Foreman) Complete Kit
$760.00$525.00
