Introducing the Jtech SmokeSheild. Get ride of laser smoke for good.
Jun 24, 2025
1 min read
Keep your workspace clear and your air clean with SmokeShield™.
Designed to pull fumes directly from beneath your workpiece when cutting with your laser.
SmokeShield™ improves performance, protects your Laser optics, and makes indoor cutting safer and more pleasant.
Whether you’re working in a home shop or a production space, it’s the clean air upgrade your laser setup deserves.
SmokeShield™ – Cut Clean. Breathe Easy.
Keep your workspace clear and your air clean with SmokeShield™ — the under-material smoke extraction system engineered for laser cutting. Designed to quietly pull fumes directly from beneath your workpiece, SmokeShield™ improves performance, protects your Laser optics, and makes indoor cutting safer and more pleasant. Whether you’re working in a home shop or a production space, it’s the clean air upgrade your laser setup deserves.
The modular, magnetic design lets you add or remove pieces as needed—build any size or shape to fit your project. Whether you’re cutting small parts or large panels, SmokeShield™ adapts to your workflow with ease.
When laser cutting, smoke is pushed downward by your air assist—right where SmokeShield™ works best. This modular platform attaches to a fan and filter system, pulling smoke from beneath your workpiece for clean, efficient extraction.
Place your material directly on top and let the powerful airflow do the rest.
Onefinity J Tech 64W Laser | 3 In 1 laser!
Onefinity J Tech 44W OCTO-PRO Laser
Onefinity J Tech Dual PRO SI 14W Laser
Onefinity J Tech 7W+ Laser Engraver
