Introducing The All New Gen 2 Elite Series by Onefinity CNC.
Nov 21, 2025
13 min read
Updated: Dec 4, 2025
The most popular Onefinity CNC Elite series, refined for the next generation of CNC routers.
Foreman (49x49") Starting at
$2375
(for a limited time)
Gen 2 Elite Series Foreman 49x49"
Gen 2 Elite Series - Batch 1
From$2,437.75$2,195.75
An Elite CNC Machine
Robust Construction: Featuring rigid, high-precision, hardened steel linear motion shafts up to 60mm in diameter (50mm Y rails, 60mm X rail), providing great rigidity. A “Z-20” heavy-duty Z-slider for high speed carves and thick aerospace grade aluminum gantry blocks and rail ends for the ultimate in ruggedness.
High-Speed Performance: Engineered for speed and accuracy, the Elite Gen 2 moves with remarkable agility—delivering higher productivity without sacrificing precision.
Advanced Motion Control: Equipped with powerful 2 Nm “anti-skip,” closed-loop stepper   motors for exceptional torque, precision 16 mm ball screws for fast, smooth, and accurate motion, and a robust 600 watt power supply to ensure ample power for every task.
User-Friendly Interface: Boasting a massive 15” high-definition capacitive touch LED screen powered by the custom-designed Onefinity REDLINE Touch controller, facilitating intuitive    operation, large buttons and step-by-step how-to animations!
Best in Class Warranty: We believe great machines should have great warranties, that’s why the Elite Gen 2 comes with a “best in class” five (5) year warranty.
Quality Assurance: Before shipping, each machine undergoes comprehensive inspection and hands-on testing—including a test carve—to ensure it meets our highest standards of quality and performance.
The Elite Gen 2 Series combines advanced technology with user-centric design, making it a reliable choice for professionals and hobbyists alike.
RE-INVENT THE CNC EXPERIENCE - AGAIN
Onefinity redefined the CNC experience—first by introducing quick and easy setup and          pioneering the use of linear rails and ball screws at a price that makers and small businesses could finally afford. This innovation forced many manufacturers to abandon outdated plastic wheels and rubber belts.
Next, we revolutionized CNC accessories for small shops with products like the Rolling–Folding Stand, Wall Mount, and the Use-Anywhere QCW.
Now, Onefinity is trailblazing again with our industry leading 5-year warranty, Gap-Free Ball Screw Covers, increased power, increased speed, increased rigidity, “Anti-Skip” Closed-Loop Stepper Motors, and our most advanced controller ever — the Onefinity REDLINE Controller.
With Onefinity, owning a high-quality, durable CNC has never been more affordable.
 ONEFINITY ELITE GEN-2 SERIES FEATURES:
  • Cutting edge, custom designed, motion control system
  • Full 3D carve simulation (no wire frames)
  • Massive 15-inch high definition industrial capacitive touch LED screen (optional)
  • Step-by-step how-to animations
  • 16mm diameter, fast travel, precision ball screws on each axis
  • X-Axis features large 60mm dia, hardened steel, linear shafts for great rigidity
  • Revolutionary “gap-free” snap in ball screw covers to dramatically reducing maintenance
  • Plug and play Easy ATC  (optional)
  • Z-Axis braking motor to prevent spindle drop
  • Industry leading 5 Year Warranty
  • High speed, long travel,  Z-20 heavy duty Z-slider with breaking motor.
  • Powerful 2 Nm “anti-skip,” closed loop stepper motors on X,Y & Y2
  • Closed Loops breaking motor on Z
  • Infrared homing sensors with auto squaring
  • 600 watt power supply for increased speed and torque
  • Plug and play wiring supported by drag chains
  • Best-in-class plug and play REDLINE Spindle with on board controls (optional)
  • Plug and play XYZ probe (optional)
  • Plug and play tool setter (optional)
  • Innovative Rotary 4th Axis  - plug and play (optional)
  • Power loss recovery and jump to line
  • Continuous and incremental jogging via touch screen
  • Feed rate override - Adjust feed rate during a carve
  • Multiple work offsets (G54-G59)
  • Quick and easy setup - start carving in under an hour
  • Solid, self supporting QCW with leveling feet (optional)
  • User friendly design with industry leading quick set-up
  • 7, 14 and 64 watt Laser (optional—plug and play)
  • Fixed or Rolling - folding stand with wobble free leveling feet (optional)
  • Each unit fully production tested with a test carve to ensure proper functionality and quality
  • A large “how to” library with a helpful and supportive community
  • Powerful Carveco Maker Advanced 3D CAD Software (1 year subscription)
  • And much more…
SOLID. RIGID. BEEFY. PRECISE.
With rails comprised of beefy, high-precision, hardened steel, linear motion shafts up to 60mm in diameter, precision machined gantry blocks and rail ends, both made from aerospace grade  aluminum, sealed, high load, linear bearings and a heavy-duty Z-Slider composed of 5/8” thick aluminum plates and 20mm hardened steel linear motion shafts, the Elite Gen 2  Series is rock solid!
RELIABLE. DURABLE. SIMPLE.
Each axis comes standard with quality 16mm ball screws for the utmost precision and speed. Revolutionary snap-in ball screw covers and sealed, high load, round linear bearings to      ensure reliable, low maintenance motion. Powerful, 2 Nm “anti-skip,” closed-loop stepper    motors for accurate, risk-free carves. A 600 watt power supply to ensure there’s plenty of power available. Advanced REDLINE controller for smart, intuitive and reliable motion control. Assembly time is minimal with many of our customers up and carving in less than one hour!
INCREASED TORQUE
The Gen-2 comes standard with a 600 watt power supply and 2 Nm closed loop stepper motors giving you more available torque and allowing you to rip through carves at faster speeds.
INCREASED RIGIDITY
The  Elite Gen-2 comes equipped with massive 60mm hardened steel linear shafts (X-Axis), making it the most rigid Onefinity ever built. In fact, the Elite Gen-2 is twice as stiff as previous models making the Gen-2 one of the most ridged machines in its class.  With the Gen-2, you can be sure that a lack of rigidity will not hold you back.
 REVOLUTIONARY GAP-FREE, SNAP-IN BALL SCREW COVERS
The Elite Gen 2 takes low maintenance to the next level. Featuring our revolutionary, patent-pending “Gap-Free” Ball Screw Covers, this machine is built to keep you running without interruptions.
Forget stopping production to clean your machine. Forget jams, binding, or downtime from lack of upkeep. The Elite Gen-2 is designed to power through long runs while keeping your rails and ball screws protected.
Onefinity has always been loved for how little maintenance it needs. Our round  rails naturally let dust roll right off, and the sealed, linear bearings keep things clean and running smoothly.
LARGER CUTTING AREA, LARGE GANTRY CLEARANCE
The Onefinity Elite Gen-2 series features a cutting area of 49” along the X-Axis and 49-3/8”  along the Y-Axis.
With a whopping 7” of gantry clearance the Gen-2 has the highest gantry clearance in its class. Having more gantry clearance is useful when you need to use fixtures or jigs to hold your parts or when you want to use thicker material on the 4th axis.
FIRST OF ITS KIND "EASY OIL SYSTEM"
The Elite Gen-2 Series features a first-of-its-kind “Easy Oil System,” designed to keep your Onefinity running smoothly for years to come. We developed a quick and convenient way to deliver oil directly into the bearing raceway—right where it’s needed most.
To lubricate your linear bearings, simply remove the custom-designed bearing cap to reveal the oil ports. Then, apply oil directly into the raceway to ensure optimal lubrication, consistent performance, and long-lasting durability.
5 YEAR WARRANTY
Great machines have great warranties. With tens of thousands of Onefinity CNCs out in the wild, years of experience and knowledge designing, testing and manufacturing CNC machines to the highest quality, we are so confident in the quality and durability of the Onefinity Elite Gen-2 Series CNC machines that we are offering an industry leading 5 Year Warranty on all mechanical components. For more info please see our Elite Gen-2 Warranty on our website.
FEATURING "ANTI-SKIP" TECHNOLOGY
One of the many benefits of the Onefinity Elite Gen-2 is that you will never lose or skip steps. With infrared homing sensors and powerful closed loop “anti-skip” stepper motors the chances of destroying an expensive piece of material or losing hours of carve time is dramatically reduced. In addition, the Onefinity Elite Gen-2 Series maximizes safety with auto stop/pause alarms. For example, if a collision occurs  the machine will stop in place, turn off the Spindle and an alarm will be given. To resume simply remove or reposition the obstruction and home the machine. You will then  be able to restart the carve in the exact spot it stopped with just a tap of the screen. Yes, it’s as awesome as it sounds!
ADVANCED. SPECIALIZED. UNTETHERED.
The Onefinity REDLINE controller with a massive 15” LED HMI (human machine interface) touch screen, is a powerful stand-alone CNC controller with fully integrated hardware and software.  With the REDLINE controller you can enjoy all the features and perks of a powerful PC-less controller at the touch of your fingertips.
With ports to easily connect an EASY ATC, Tool Setter, XYZ Probe, laser, 4th axis and full support for the REDLINE spindle, all with direct on screen controls making the REDLINE Controller the most  advanced CNC controller we’ve ever tested and it’s available for an incredible, unmatched price.
The Onefinity REDLINE controller also supports standard joypads and a rotary attachment!
 ADVANCED REDLINE CONTROLLER Features:
  •  Great wire management—Only 2 cables running to touch screen
  • Fully 3D (no wire frame) tool path display so you can see your carve in real time
  • No USB disconnects. Files download to the controller ensure a smooth, successful carve
  • Automatic G-Code scan. Determine issues prior to run (e.g. limit extents/invalid commands)
  • Preloaded bit diameters to save time while probing. No typing necessary.
  • Plug and play joypad for quick and easy jogging
  • Increase or decrease spindle speed while running
  • Ability to save coordinates
  • Simple, easy-to-use screen layout
  • Expandible Wi-Fi
  • Jog while paused
  • And much more...
Power Loss Recovery.  Jump To Line.
Dramatically reduce the chance of a lost or damaged carve.  The Onefinity REDLINE controller has built in power loss recovery.  If you lose power during a carve, the controller will give you the option to resume the carve upon power recovery at the very spot it last carved.  This can save you hours of time and hundreds of dollars worth of materials.
The jump to line feature allows you to skip to any point in a carve at any time.  If you are  running a long carve and need to step out of the shop, you can stop the carve, turn off the machine, and start it the next day from where you left off.
STEP-BY-STEP, HOW-TO ANIMATIONS!
Most CNC controllers are functional—but flat. Endless numbers. Dry screens. They get the job done, but they don’t inspire. The REDLINE controller changes everything.
With fluid animations and real-time visual feedback, everyday CNC work becomes a seamless, almost cinematic experience.
Routine tasks come alive, guided by motion and visuals that feel effortless.
New users are welcomed intuitively, learning through experience instead of spreadsheets.
Seasoned makers gain precision and speed, interacting with a sleek, modern interface designed to feel as natural as it is powerful.
This isn’t just a controller — it’s a leap forward in how you interact with the Onefinity. Numbers still run in the background, but your eyes enjoy a clear, visual, and modern experience that feels as powerful as it is fun.
Step into the future of CNC with the REDLINE controller, and experience the animations that bring every operation to life.
Here’s a glimpse of the stunning animations that bring the REDLINE CNC controller to life
INFRARED HOMING SENSORS
The Onefinity Elite Gen 2 Series uses infrared homing sensors with auto squaring. With the use of dual Y-axis sensors, every time you home the Onefinity you can be sure that it’s completely square and at its exact 0 coordinates. The Onefinity homing sensors are not subject to       mechanical failure and are not affected by temperature changes making them extremely  reliable and accurate.
PLUG AND PLAY WIRING SUPPORTED BY DRAG CHAINS
The Elite Gen-2 Series, while very advanced and feature rich, keeps true to what customers love about the Onefinity. The Elite Series features industry leading, easy to assemble, simple and quick setup. Every wire and connection for each axis, laser, touch probe, tool setter and spindle is clearly labeled and designed to prevent improper connection.
ONEFINITY CNC GROWS WITH YOU
Onefinity is built to grow with you. Start with the base machine and your own laptop to begin creating right away at the most affordable entry point As your skills and ambitions expand, your Onefinity can evolve right alongside you.
Upgrade anytime with powerful enhancements like the REDLINE HMI Touch Screen and REDLINE Spindle, or add convenience and stability with the QCW Frame or Fixed Table. For greater precision, integrate the Touch Probe or Easy Z Tool Setter. When you’re ready to push boundaries, explore advanced accessories like the Revolution 4th Axis Rotary, Easy ATC, and Air Weights Vacuum Table.
No matter where you are on your CNC journey—from first cuts to professional production—Onefinity grows with you every step of the way.
UNMATCHED SPEED, POWER, AND DURABILITY.
The Gen-2 Z-20 (Z-Slider) is a powerful, rigid and speedy, heavy duty Z-slider. Offering unmatched speed, torque and precision due to the 16mm ball screw and a powerful “anti-skip,” closed loop stepper motor with built in brake to ensure your spindle doesn’t drop after powering off or hitting the emergency stop. Along with a large range of motion, the Z-20 is a solid Z-slider that preforms like no other.
  • Gen-2 Z-20 Heavy Duty Z-Slider Features:
  • Powerful “anti-skip” closed loop stepper motor with built-in brake
  • Large 20mm hardened steel linear shafts maximizing rigidity
  • Slim design for added X-Axis travel
  • Sealed, high-load, linear bearings
  • 16mm ball screw for great speed and rigidity
  • 160mm  of total travel distance
  • Pre-set rapids of 300 inches per minute for fast 3D Carves (adjustable)
  • Provisions for mounting a laser and other accessories
  • 3/4” thick precision machined back plates
  • And more...
INDUSTRY LEADING QUICK SETUP
Our competitors keep trying but they just can’t find a way to design a machine that’s as fast and easy to set up as the Onefinity. And Keeping true to what customers love about the Onefinity CNC, the Elite Gen 2 can be assembled very quickly. Everything is plug and play and only 12 bolts are required to      assemble the Onefinity (8 bolts to fasten the X-Axis to the Y-Axis and 4 to attach the Z-slider). Once your machine is fastened together, just mount your display and screw the Y-Axis to your table or QCW. Most customers are carving in less than an hour!
REDLINE SAFETY APPROVED SPINDLE
The Onefinity Elite Gen-2 Series can be purchased with an 80mm REDLINE Spindle. REDLINE      Spindles are the only safety approved  plug and play spindles on the market. The REDLINE    Spindle Kits are of the  highest quality and feature and all metal VFD enclosure (no plastic or 3D printed parts) along with properly grounded and shielded wires and cables. The REDLINE Spindle Kits ensure all power lines are properly filtered and the spindles feature four ceramic bearings
QCW (QUICK CHANGE WASTEBOARD) WITH LEVELING FEET (OPTIONAL)
Using a custom designed extrusion that is engineered to be rigid and self-supporting without the need for a table to prevent sag, the QCW is a great addition to the Onefinity Elite Series. The Onefinity CNC is designed to be used by simply bolting it to a solid table, however, some customers don’t have the time or desire to build or source a solid table. The Onefinity QCW is solid enough to be used on any surface due to its rigid custom extrusions and wobble-free leveling feet. With the use of the QCW, you do not need to worry if your surface is level and flat. Note: All QWC’s come with leveling feet and a set of Oops Clamps.
ROLLING - FOLDING OR FIXED STAND LEG KIT (OPTIONAL)
 When combined with the amazing QCW, users  can quickly and easily add very solid Fixed or Rolling - Folding legs. Turn your Onefinity CNC into a stand alone money maker. Don’t waste time and money building a flat table when you can use that time to make awesome things!  The innovative design of the Onefinity gives you the option to easily add a solid, compact table that can be moved from one location to another. In addition, the unique design allows you to place your vacuum and other things right underneath, saving a lot of space.
7, 14 and 64 WATT LASER (OPTIONAL)
The Onefinity CNC offers you the ability to quickly add a quality plug and play J-Tech laser that is completely plug and play. Many of our customers create mind blowing carves using their Onefinity CNC, but if you really want to set yourself apart from the crowd add some “freakin’ laser beams.”
EACH UNIT FULLY INSPECTED
COMPLETE WITH A TEST CARVE
 Onefinity’s quick and easy set up allows us to do something no other company can; each machine is fully assembled, thoroughly inspected and tested, which includes performing an actual test carve. Your machine is then packaged for shipping along with the test carved “Team Onefinity” sign. No other CNC company can ensure your machine is at its highest quality before leaving the factory.  They may test parts of the machine, but don’t be fooled, they don’t test the full machine.
Easy Z Tool Setter
Easy Z Tool Setter
PLUG AND PLAY TOOL SETTER AND XYZ TOUCH PROBE
The Elite Gen-2 Series Tool Setter is a semi automatic tool offset probe that makes it easy to run jobs using multiple tools without the need to stop and re-zero manually. The XYZ Probe allows you to quickly and precisely zero your CNC's X, Y, and Z axis.
A LARGE HOW-TO LIBRARY WITH A HELPFUL AND SUPPORTIVE COMMUNITY
The Onefinity community prides itself on being supportive, helpful, and boasting a wealth of resources including how-to videos and informative blogs. With knowledgeable community members and administrators, you will have access to many helpful creators and makers at all hours of the day and night. Onefinity has over 100,000 members across our forums, Facebook group, Instagram and YouTube channels. Watch a number of exciting educational series such as Morgan Hop’s “Onefinity University,” Kyle Ely’s “Learn your CNC,” and Two Moose Design’s “5 Projects to Make and Sell” along with many others. You will find an abundance of  resources and help to ensure you are successful and productive with your Onefinity.
POWERFUL 3D CAD/CAM SOFTWARE INCLUDED
All Onefinity Elite series machines include a 1-year subscription to the full-featured 3D design and machining program Carveco Maker.
Featuring easy-to-use design tools and the ability to create highly accurate, dependable toolpaths, Carveco Maker is a powerful CAD/CAM program providing you the ability to create virtually anything you imagine or desire.
Whether you’re a weekend maker, traditional craftsman, or brand new to working with a CNC router, Carveco Maker provides you with all the tools you need to create high-quality 2D and 3D products quickly and easily.
Already have CAD/CAM software you like? No problem! The Onefinity accepts standard G-code, so you can use your preferred software.
FULLY UPGRADEABLE
When you purchase a Onefinity CNC you can be confident that it will grow with you in your CNC journey. When you purchase a Onefinity you’ll have the ability to upgrade to a larger size or add any accessory no matter what version Onefinity you have.
Via the revolutionary IPP (Infinite Possibilities Program), when upgrading a Onefinity, a discount is given when you return parts you no longer require. We take these returned parts and refurbish them, pair them with other returned parts to complete a fully functional Onefinity CNC. We then use these units to help veterans, schools and maker spaces. We are very proud of this program!
The IPP first started with the Journeyman and X-50 Woodworker upgrades, allowing users to quickly expand the size of their machine.  We then expanded the program to include our MASSO upgrade kits. We are now proud to announce that a kit will be available allowing you to upgrade your existing Onefinity Elite machine to become part of the Elite Gen-2 class. We expect to have different upgrade packages that allow you to upgrade some or all of your machine. Please keep an eye on our forum to learn more. In addition, we encourage you to make requests on our forum for any upgrades you’d like to see. Gen-2 Upgrade kit(s) coming soon!
Orders for the Onefinity Elite Gen-2 will start on Tuesday November 25, 2025, 11am Eastern.
This offer is for a limited time and includes the following items:
GEN 2 ELITE SERIES PACKAGE
Foreman 49x49" Starting at
$2357 USD
General Disclaimer:While Onefinity has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations,  system/component/options availability are all subject to change without notice. Product design specifications and colours are subject to change without notice and may vary from those shown. Errors and omissions excepted. Images displayed  are for illustration purposes only. The images are intended to help illustrate the product and it’s functions and are not indicative of actual relative differences.
