USA Tariff Information
REDLINE ELITE EARLY ADOPTER PROMO PACKAGE. Only $3475 💥😲
Aug 12, 2025
4 min read
Updated: Aug 27, 2025
Update: We're SOLD OUT!
Meet the Onefinity Elite Foreman (48" x 48") — our flagship 4x4 CNC machine — now paired with the advanced Redline CNC Controller for unmatched power, precision, and ease of use.
For a limited time, when you grab this powerhouse, we’re loading it up with $1,255 in FREE upgrades:
✅ STIFFY — Boost rigidity for heavy cuts ($200 value)
✅ Redline 80mm Spindle — Whisper-quiet, pro-grade performance ($800 value)
✅ XYZ Probe — Perfect setups every time ($100 value)
✅ Suckit SM Dust Boot — Keep your shop clean ($80 value)
✅ Tool Setter — Lightning-fast, accurate tool changes ($75 value)
This isn’t just a CNC — it’s a complete, professional-grade cutting system that’s ready to tackle wood, plastics, and soft metals with precision and speed all at an incredible price you won’t want to miss!
Hurry! Sale is only for a limited quantity! Once we run out, they’re gone!Sale opens Thursday, August 14th, 2025 at 10am eastern time zone. Don’t miss this amazing deal!
Get the deal here⤵️
The Redline Elite Early Adopter Promo Package.  This is a VERY limited batch of machines at this price.  Once it's sold out, it's gone.
Orders open Thursday, Aug 14th, 2025 | LIMITED QTY
The REDLINE Elite early adopter promo features the Onefinity Elite Foreman, REDLINE Controller, 80mm REDLINE Spindle, Easy-Z, XYZ Probe, Suckit SM Dust Shoe and more...
Our Biggest Deal EVER! – Grab it before it’s gone!
Important Note: This promo has a 5-6 week lead time.
Designed for the more advanced user. With "anti-skip" closed loop steppers motors, Z-20 Heavy duty Z-slider, and the ALL NEW Redline CNC Controller with integrated 15" touch screen all standard, the Elite series is for the serious CNC enthusiast. With a long list of features and upgrade options, the Elite series is for customers that want to get the most advanced functions and accessories while maintaining exceptional rigidity, precision and speed. If you have a business and need to keep output consistent with reduced cutting times the Elite Series is for you.
REDLINE Elite Early Adopter Package Includes:
  • Onefinity Elite CNC
  • Z-20 Z slider with 165mm travel with 80mm mount
  • Redline Controller w/ built in 15” Touch Screen
  • Closed Loop 1.2nm Stepper Motors on X and Y axis
  • Closed Loop 1.2nm Braking Stepper Motor on Z axis preinstalled
  • Plug and Play wiring harness
  • 1616 Ball Screw on X and Y Axis (Travel Per Revolution is 16mm)
  • 1610 Ball Screw on Z axis (Travel Per Revolution is 10mm)
  • Drag Chains on X and Y axis
  • Four (4) Infrared Homing Sensors (Z axis sensor preinstalled).
  • Foreman Cutting Area: 48 1/8""(X) x 48 1/2"(Y) x 6 1/4"(Z)
  • CAD Software: Carveco Maker 12 Month Subscription FREE Limited Time Offer
  • 1x Bits & Bits ¼ downcut spiral bit
  • 1 Year Warranty
  • Lifetime technical support with North American agents
  • Physical test carve done on the machine during QC Stage
  • Four (4) Y/B axis riser blocks (Foreman only)
  • Machine requires one 15 amp 110v to operate (Spindle and Vac need separate circuits) in North America. In countries that use 220v, it will come preconfigured for 220v.  Spindle will require it's own 110 or 220v power port.
BONUS PROMO INCLUDED ITEMS:
  • Eazy-Z Tool Setter
  • Redline Spindle (80mm) (110v or 220v)
  • XYZ 3 Axis Touch Probe
  • Suckit SM Dust Boot
  • 3rd Rail Stiffy
Onefinity Elite Series features:
  • Advanced REDLINE controller
  • Massive 15-inch high-definition industrial capacitive touch LED screen
  • 600w Power Supply
  • Rigid, high precision, hardened steel, linear motion Shafts
  • High speed, long travel, Z-20 heavy duty Z-Slider
  • Powerful “anti-skip,” closed loop stepper motors
  • Preinstalled braking motor on Z axis to stop spindle drop
  • Infrared homing sensors with auto squaring
  • Fast travel, precision ball screws on all axis
  • Conveniently located Emergency Stop
  • Plug and Play wiring supported by drag chains
  • Wi-Fi enabled with remote access
  • Power Loss Recovery
  • Jump to Line
  • Continuous and incremental jogging via touch screen
  • Feed Rate Override - Adjust feed rate during a carve
  • Spindle Speed Override
  • Multiple Work offsets (G54-G59)
  • Joypad Support for Jogging
  • Micro Tramming
  • Quick and easy setup - start carving in under an hour
  • Open ended front to back allowing for 'tiling' (carving pieces longer than the cutting area)
  • User friendly design
  • 4th Axis Rotary Plug & Play Support
  • Rapidchange ATC support built in
  • Rapids at 600IPM
  • Spindle connection with on board controls
  • Each unit fully production tested with a test carve to ensure proper functionality and quality
  • A large “how to” library with a very helpful, active, and supportive community
  • Powerful Carveco Maker Advanced 3D Cad Software (1 year subscription)
  • And much more…
Elite Series cannot be mounted vertically.
Designed & Manufactured in Canada.
Technical Support located in North America.
Each unit is fully assembled and tested in-house before shipping. A class exclusive.
Optional Accessories:​
  • ​Bits and Cutters. You will need to supply your own bits and cutter.
  • Table | ​QCW (Quick Change Waste board) Frame & Fix Stand
  • 7, 12, 44 & 64 watt Plug & Play JTech Laser
  • 4th Axis Rotary 'The Revolution'
  • ATC (automatic tool changer) by RapidChange for Redline Controller
  • Vacuum table by AirWeights
To learm more about the REDLINE Controller please visit: redlinecnc.com
