✨ Suckit SM Dust Shoe — The Perfect Dust Solution for Your EASY ATC!
Jun 13, 2025
1 min read
Dust collection just got smarter with the Suckit SM Dust Shoe — engineered specifically to work seamlessly with 80mm Spindles and the Onefinity EASY ATC.
👉 Why you’ll love it:
  • Mounts to the spindle — moves with the Z axis so bristles always surround the cut
  • Ideal for 3D carves & deep pockets — consistent, effective dust removal
  • Quick bit changes — bottom section removes in seconds for easy access
  • Swap brush rings fast — no need to remove the bit!
⚡ Includes:
  • Suckit SM Dust Shoe (top + bottom with magnets)
  • 30mm & 50mm brush rings
  • All required hardware
💡 Easy installation: Just slide over the spindle and tighten the thumb screw. That’s it!
🎥 Watch how simple it is to install and use:👉 Suckit SM Dust Shoe Installation Video
Compatibility:✅ 80mm spindles only❌ Not compatible with 65mm spindles or Makita routers
🌟 FREE 3D adapter files!Want to use a different hose? We’ve got you covered with free printable adapters:👉 Get the 3D files
Suck It SM (Spindle Mount) Dust Shoe (EASY ATC Compatible)
Suck It SM Replacement Parts Pack: Rings, 1" & 2" Brushes
