Introducing the Redline CNC Controller
Aug 12, 2025
The Redline CNC Controller is an all new, built from the ground up, controller that Onefinity designed in conjunction with Redline to create a modern CNC controller with advanced features, expandability, and ease of use at it's core.
Advanced Redline CNC Controller
The All New Redline CNC Controller
Redline CNC has created some of the best CNC spindles on the market with their all metal VFDs, 1.5kw and 2.2kw power options, 80mm and 65mm size options, and safety certification, leading the way in spindle quality in the hobby CNC market.
REDLINE ELITE EARLY ADOPTER PROMO PACKAGE
By partnering with Redline, we’ve combined our five years of experience and the insight gained from tens of thousands of machines in the field to deliver exactly what our customers have been asking for: the most-requested features, simplified workflows, an intuitive layout and GUI, and innovations inspired by real-world support feedback.
This collaboration has resulted in a controller designed to be loved by our users and to redefine the standard for modern CNC machines—just as we did in 2020 with the introduction of the Onefinity CNC, making ball screws standard; again in 2023 with the Elite Series, which brought closed-loop steppers to the hobby CNC market; and now, once more, with the release of the advanced Redline CNC Controller.
Check out the first look at the advanced Redline CNC Controller from our AWFS 2025 unvailing:
Want to see more of it in action?
Check out what our friends showed when visiting us at the AWFS Booth (along side our upcoming release, the Onefinity CNC 4x8 Machine, "The Full 8" )!
General Specifications
Elite Redline Controller
Stepper Motor Compatibility
Closed Loop with Error Output
Number of Axes
4
Motion Control
Custom Real-Time Operating System
Motor/Controller Power
Separate
Maximum Motor Supply Voltage
48V
Maximum Motor Input Current
10A
USB Supply Voltage
4.8V ~ 5.25V
USB Power
2.5W
(500mA)
Active Cooling
N/A
E-Stop
External
(Motor power supply)
Operating Temperature
5°C to 45°C
E-Stop
External on
motor power
Stepper Drivers
Number of Drivers
5
Driver Configuration
X, Y1, Y2, Z, A
Stepper Interface
Step, Dir, Enable, Error
Differential drive (>2V @ +/-20mA)
Error Detection
Error Input
Stall Homing
No
Sensor Homing
Yes
Dedicated Connectors
Microstepping
Supported
Configured on motor
5V to 48V
Motor Output Current
7A Supply Pin Rating
Max total output 10A RMS
Maximum Step Rate
100kHz
Interfaces
Power
6-Pin
Molex Mini-Fit Jr
USB
USB 2.0
USB-C
Stepper
8-Pin
Molex Mini-Fit Jr
Dedicated Homing Sensor
3-Pin
Molex Mini-Fir Jr
Inputs
8 Isolated
Normally-Open Switch
DB-25 Connector
Outputs
4 Isolated
50V/100mA RMS
DB-25 Connector
I/O Expansion Bus
Yes
Probe Input
Dedicated connector
Tool Setter Input
Dedicated connector
PWM/Laser Output
5V/15mA
10kHz max
Adjustable Resolution
Dedicated connector
VFD Spindle
RS-485
Dedicated connector
Future Expansion
SD Card Interface
Software
Compatibility
Windows, Linux, Mac
Free Software Updates
Over-the-air
USB Drive
Free Firmware Updates
USB
Jogging
Distance
Continuous
Game Controller
Pendant1
Probing
Z-Height
Probe Block
Overrides
Feed
Spindle
Power-Fail Recovery
Supported
Jump to Toolpath Line
Supported
Tool Change with Tool Setter2
Manual
Rapid Change ATC
Spindle Control
Manual via User
On/Off via Output
VFD via RS-485
Work Offsets
9
Toolpath Visualization
G-code Viewer
3D Display
Remote Access
File Manager Web Interface
Webcam
Mobile Support1
Android
iOS
  1. In development ↩↩
  2. Additional support coming soon ↩
Interface and Web UI v1.0
(While Onefinity and Redline has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations, system/component/options availability are all subject to change without notice. Product design specifications and colours are subject to change without notice and may vary from those shown. Errors and omissions excepted. Images displayed are for illustration purposes only. The images are intended to help illustrate the product and it’s functions and are not indicative of actual relative differences.)
2025
