RealTime / Redline Controller Firmware 1.4.18
- Mar 30
- 1 min read
1.4.18 Firmware is now available for all Redline HMI and Realtime Controller controlled machines, plus Windows, Mac, and Linux!
(3/29/30)
Download Now: Downloads - RealTime CNC
Added
Download speed readout to software update dialog
Scroll buttons for file manager (Raspberry Pi)
Support for more touchscreen devices (Redline only)
Fixed
Software update check failing on MacOS
Startup units inconsistent if set to imperial and controller is already in imperial mode
Scaling issues on NumericEntry dialog box on MacOS
Font scaling issue on spindle warmup dialog when timer was started
Bug where some wireless gamepads could corrupt jog direction and cause missed steps resulting in machine position error
Bug where some wireless gamepads could interrupt system movements like homing or probing
Bug where rotary axis enable could be stuck in the enabled state
Bug where rotary acceleration units were not displayed correctly
Bug where some gamepads would not be detected on startup
M4 command not setting the spindle direction correctly on some VFDs
G28 not working in MDI mode
Changed
Improved motion smoothing of gamepad jogging at high speeds
Scaling and readability enhancements
Web interface improvements for weak or unreliable network connections
Improved network manager (Raspberry Pi version) and connections to 2.5GHz networks
Changed font size on file manager (Raspberry Pi) for improved readability
Updated web interface so all resources are served locally
Improvements to jump-to-line including better support for jumping to lines with arcs
