Gen 1 Elite Series vs. Gen 2 Elite Series: Which Onefinity CNC is Right for You?
Mar 9
The Gen 1 Elite Series was a breakthrough, introducing closed-loop motors and industrial controllers to the hobbyist market. It laid the foundation for the Gen 2 Elite Series, which refined that power into a stiffer, more user-friendly, and more durable package. For any CNC hobbyist, the choice between these two comes down to how you want to interact with your machine every day.
Key Differences between the Gen 2 & Gen 1 Elite Series
The CNC Controller Debate
The choice between these two generations is often a choice between different controller philosophies.
Masso G3 Touch (Gen 1): This is a proven, standalone industrial controller that was originally introduced in 2020. It is celebrated for its reliability because it does not require an external computer and features a massive 15-inch industrial touch screen.
Redline RealTime (Gen 2): Introduced in 2025, this system was designed specifically to integrate with the Onefinity ecosystem. It offers a more user-friendly interface, faster real-time motion control, and deeper integration with Onefinity hardware and accessories.
Unlike the wireframe previews found in earlier systems, the Redline HMI offers modern 3D visualization that allows you to see your carve progress with much greater clarity.
CNC Machine Power and Performance
If your goal is to grow your CNC business, you need a machine capable of "ripping" through carves at higher speeds while maintaining accuracy.
The Elite Series was already a leader in this area, but the Gen 2 platform introduces electrical and motor upgrades that provide a distinct competitive advantage for both beginners and pro operators.
Improved Motion and Z-Axis Stability
Beyond the primary rail upgrades, the Onefinity Gen 2 Elite Series introduces significant structural reinforcements to the vertical assembly, ensuring superior precision during heavy-duty operations.
These updates focus on stabilizing the machine's most critical moving components to handle increased speeds and forces without compromising accuracy.
The machine comes standard with the Z-20 heavy-duty Z-slider, which features larger 20 mm solid linear rail shafts and a 1610 ball screw to facilitate faster, more rigid 3D carves.
While the structural mount is stronger, both generations utilize the same 1.2 Nm braking motor on the Z-axis to ensure secure vertical positioning and prevent spindle drops during power loss.
A Modernized Electronics Ecosystem
The transition to the Gen 2 platform represents a major shift in control technology, moving toward a system designed specifically for the Onefinity environment.
Regarding hardware integration, the Gen 2 utilizes the Redline HMI paired with the RealTime Motion Controller, a system designed specifically for the Onefinity ecosystem.
This modern platform offers a more user-friendly interface and smoother operation compared to the earlier generation technology found in the Masso G3.
The deeper integration with Onefinity hardware and accessories makes the Gen 2 a more refined and future-ready CNC solution for any business.
Optimized Maintenance and Travel
Structural changes in the Gen 2 series do more than just increase strength; they also improve the machine's longevity and work area.
For integrated protection, the Gen 2 Elite includes integrated ball screw covers that protect the ball screws and ball nuts directly at the source.
By shielding these components from dust and debris, the Gen 2 offers improved reliability and longevity compared to the exposed components on Gen 1 machines.
 Furthermore, the redesigned gantry blocks allow these covers to pass through them, which enables greater X and Y travel within the same machine footprint, maximizing your available production space.
Choosing Your Path with Onefinity
Deciding between the Gen 1 and Gen 2 Elite Series ultimately depends on whether you prioritize a proven industrial standard or the latest advancements in CNC rigidity and protection.
The Gen 1 Elite remains a powerhouse for those who value the standalone reliability of the Masso G3 controller and a machine that has successfully powered thousands of shops since 2023.
 However, the Gen 2 Elite Series represents a significant leap forward by offering a massive 100% increase in rigidity and the modern, 3D-capable Redline electronics ecosystem.
With the addition of integrated ball screw covers and upgraded 2 Nm high-torque motors, the Gen 2 is specifically engineered to reduce maintenance downtime and maximize production speed.
Whether you are a beginner looking for the most user-friendly entry point or an experienced pro needing a future-ready platform, both machines embody the Onefinity commitment to quality and Infinite Possibilities.
