Introducing the Award-Winning Onefinity FULL-EIGHT: Turn Your 4×4 CNC Into a 4×8!
Nov 6
5 min read
Bigger Projects. Bigger Possibilities. Onefinity Precision.
What if you could turn your Onefinity Elite Foreman 4×4 into a full 4×8 CNC without replacing your machine?
And what if you could do it automatically, without stopping to manually reposition your material?
Well, now you can! And all for UNDER $6000 USD!
Introducing the Onefinity FULL-EIGHT 4×8 Auto-Tiling CNC Table, winner of a 2026 WOOD Magazine Innovation Award!
And for those who don't already own a Onefinity CNC, we're also introducing the Onefinity Gen 2 Elite FULL-EIGHT 4×8 Complete CNC System, an all-in-one package that includes the CNC machine, spindle, controller, automatic tiling table, HD Fixed Stand, software, and essential accessories.
Onefinity FULL-EIGHT 4×8 Auto-Tiling CNC Table Add-On | Batch 1
From$2,095.00$1,695.00
Onefinity Gen 2 Elite FULL-EIGHT 4×8 Complete CNC System | Batch 1
From$6,895.00$5,985.00
Two ways to go BIG. One innovative solution.
Instead of Making the CNC Bigger, We Made the TABLE Move!
Traditional 4×8 CNC machines typically achieve their larger working area by extending the CNC gantry's travel, often using long rack-and-pinion drive systems.
We wanted to do things differently.
The FULL-EIGHT takes the proven speed, rigidity, and precision of our Elite Foreman 4×4 and combines it with an innovative, ball-screw-driven moving table.
The CNC stays in place while the table automatically advances your material!
This allows you to machine full 4×8 projects while maintaining the advantages of the compact, precision ball-screw-driven Onefinity Elite platform.
All the capability of a 4×8. All the precision you expect from Onefinity.
Automatic Tiling: No More Manually Moving Your Material!
If you've ever tried making a project larger than your CNC's cutting area, you're probably familiar with tiling.
You cut one section, stop the machine, manually move your material, realign everything, and then continue cutting.
It works, but it's time-consuming and leaves room for alignment errors.
The FULL-EIGHT changes that!
Here's how it works:
  1. Load your material. Place your full 4×8 sheet onto the FULL-EIGHT table.
  2. Start carving. Your Elite Foreman machines the first section of your project.
  3. Automatic advancement. The FULL-EIGHT moves the material into position for the next section.
  4. Keep creating. Your Onefinity machines the remaining section, completing your larger project.
No manually repositioning your material. No manually realigning between tiles.
And because the FULL-EIGHT uses precision ball-screw-driven advancement, each movement is designed for accurate, repeatable positioning.
From cabinetry and furniture to full-size signs, decorative wall panels, and production projects, you can now think well beyond 4×4.
Why Ball Screws Instead of Rack and Pinion?
Most traditional 4×8 CNC machines use rack-and-pinion drive systems to achieve their extended travel.
Those systems have their place, but they can require periodic adjustment and maintenance as components wear.
The FULL-EIGHT uses a different approach, combining the Elite Foreman's existing precision ball-screw-driven axes with automated ball-screw-driven material advancement.
That means:
  • Precision: Low-backlash motion for accurate, repeatable positioning.
  • Speed: Retain the Gen 2 Elite Foreman's rapid movement capabilities, up to 600 IPM on its X/Y axes.
  • Rigidity: Keep the solid 4×4 gantry structure rather than extending it to eight feet.
  • Less Maintenance: Avoid the long rack-and-pinion drive systems commonly found on traditional 4×8 CNC machines.
  • Consistency: Precise material advancement helps maintain alignment between tiled sections.
Bigger projects don't have to mean compromising on the performance you love about Onefinity.
Option 1: Upgrade Your Existing Elite Foreman With the FULL-EIGHT Table
Already own an Elite Foreman 4×4?
You don't need to buy another CNC!
The FULL-EIGHT is available as a standalone upgrade table that transforms your compatible Elite Foreman into a machine capable of machining full 4×8 projects.
It's compatible with:
  • Onefinity Gen 2 Elite Foreman 4×4 using RealTime/Redline
  • Onefinity Gen 1 Elite Foreman 4×4 using RealTime/Redline
  • Onefinity Gen 1 Elite Foreman 4×4 using MASSO
Important: The FULL-EIGHT does not work with machines running BB Buildbotics controllers, Original or Pro Series machines, or machines smaller than the Foreman 4×4.
Already own a QCW? The FULL-EIGHT replaces your existing QCW frame, but your compatible QCW HD Leg Kit can be reused!
Don't have legs? A dedicated FULL-EIGHT leg kit is also available as an optional purchase.
Please Note: The standalone FULL-EIGHT Table does NOT include the Elite Foreman CNC machine or legs. These are sold separately.
Already own a compatible Foreman? Keep your CNC and expand your possibilities!
Option 2: Get Everything With the FULL-EIGHT Complete CNC System!
Don't already own a Onefinity CNC?
Or maybe you're ready to upgrade your workshop with a fully equipped 4×8 CNC setup?
We've got you covered!
The FULL-EIGHT Complete CNC System combines our Gen 2 Elite Foreman Small Business Package, the innovative FULL-EIGHT Auto-Tiling Table, and the HD Fixed Stand into one convenient package.
Everything you need for a complete 4×8 CNC setup, in one package!
What's Included?
1. Gen 2 Elite Foreman Small Business Package
  • Gen 2 Elite Foreman 4×4 CNC Router
  • REDLINE 80mm Spindle
  • Redline Controller with 15" Touch Display
  • RealTime CNC RTS-2 closed-loop control system
  • Heavy-duty Z-20 Z-Slider
  • Precision ball screws and closed-loop motors
  • Dust Shoe
  • XYZ Probe
  • Tool Setter
  • Bits & Bits 1/4" Downcut Spiral Bit
  • Carveco Maker 12-Month Subscription
  • FREE Filefinity Access
  • 5-Year Mechanical Warranty
  • Lifetime North American Technical Support
Bonus Accessories:
  • Downtown Jenny .125" Endmill
  • Oops Clamps Large
  • Exclusive Onefinity Banner
2. FULL-EIGHT 4×8 Auto-Tiling Table
The same award-winning automatic tiling system that advances your material for full 4×8 projects without manual repositioning.
3. HD Fixed Stand
A dedicated, heavy-duty foundation for your complete FULL-EIGHT CNC setup.
Unlike the standalone FULL-EIGHT upgrade, the Complete CNC System includes both the CNC machine and the stand!
Less setup. More making. Bigger possibilities.
Compatible With Vectric, Carveco, and Automatic Tool Changers
The FULL-EIGHT supports compatible tiling workflows in Vectric and Carveco, two popular CNC design and toolpath software platforms.
And for those looking to take automation even further, the FULL-EIGHT also supports Onefinity Easy ATC by RapidChange Automatic Tool Changer configurations with RealTime/Redline and MASSO controllers.
ATC tooling can be positioned at the front of the QCW mounting area using the appropriate QCW mount or within the machine's usable cutting area on the table top.
Combine automatic material advancement with automatic tool changes, and you've got a seriously capable CNC workflow!
A 2026 WOOD Magazine Innovation Award Winner!
We couldn't be more excited that the FULL-EIGHT has been recognized as a 2026 WOOD Magazine Innovation Award winner!
The award recognizes the innovative moving-table concept that makes full 8-foot machining possible using a compact 4×4 CNC platform.
Instead of following the traditional approach to building a larger CNC, the FULL-EIGHT provides a different way to tackle full-sheet projects.
And we're proud to bring that innovation to Onefinity owners.
DOES THE FULL-EIGHT REQUIRE MORE SPACE THAN A TRADITIONAL 4×8 CNC?
Not necessarily!
While the FULL-EIGHT uses a moving table to automatically advance full-length material, its overall workspace requirements are comparable to those of traditional 4×8 CNC machines.
The FULL-EIGHT frame measures approximately 60⅛" wide × 98¼" long.
Recommended Workshop Space:
  • Minimum: 6' × 12.5'
  • Ideal: 10' × 14'
Traditional 4×8 CNC machines also require additional room for material loading, machine operation, cable management, and maintenance.
Bigger projects don't automatically mean needing a bigger workshop!
Whether you're an existing Elite Foreman owner who wants to expand your machine or someone looking for a complete 4×8 CNC solution, the FULL-EIGHT opens up an entirely new world of possibilities.
Build larger furniture. Cut full-sheet cabinet components. Create oversized signs. Take on projects that simply weren't possible within a traditional 4×4 cutting area.
And do it while keeping the precision, speed, rigidity, and support that make Onefinity CNC machines stand out.
Two Ways to Get the FULL-EIGHT:
Already own a compatible Elite Foreman 4×4?
Want a complete, ready-to-run 4×8 CNC?
ONEFINITY FULL-EIGHT
One Machine. Infinite Possibilities. Now With FULL-EIGHT Reach!
