Introducing the NEW RealTime CNC Pendant Kit!
Updated: Nov 7
Precision CNC Control. Right in Your Hand.
Take control of your Onefinity CNC with the RealTime CNC Pendant Kit, an industrial-grade Manual Pulse Generator (MPG) designed to make jogging your machine easier, more precise, and more convenient than ever.
For years, Onefinity owners have enjoyed the simplicity of jogging their machines with an Xbox-style Joypad. Now, there's another option for those who prefer the precision and tactile feel of a traditional industrial CNC handwheel.
With the RealTime CNC Pendant, you can move your machine with incredible precision while keeping your eyes on your cutting tool and workpiece, instead of constantly looking back at your controller or computer screen.
Whether you're positioning your bit, setting your work zero, aligning a workpiece, or making fine adjustments, the RealTime CNC Pendant puts precision control right at your fingertips.
PRECISION YOU CAN FEEL
Unlike traditional joystick-style controllers, the RealTime CNC Pendant features a high-resolution, 100-pulse-per-revolution optical handwheel.
Each click of the handwheel provides precise, controlled machine movement, giving you the tactile feedback needed for accurate positioning.
Need to move across your work area? Select a larger movement increment.
Need to make a tiny adjustment to your bit's position? Switch to a finer increment.
With three customizable movement scales (1X, 10X, and 100X), you can easily switch between faster positioning and incredibly fine adjustments.
You can even configure custom travel distances per revolution or per click, with separate settings for imperial and metric measurements.
MULTI-AXIS CONTROL
Quickly select the axis you want to move using the pendant's convenient rotary selector.
X-Axis: Move left and right.
Y-Axis: Move forward and backward.
Z-Axis: Raise and lower your cutting tool.
4th Axis: Control a compatible rotary axis or linear axis.
Additional Functions: Two extra selector positions can be assigned to supported functions such as spindle control or feed and speed overrides.
No more switching between on-screen controls just to make a small adjustment.
Simply select your axis, choose your movement increment, and turn the handwheel.
BUILT-IN STOP AND ENABLE BUTTONS
Convenience and control go hand in hand.
The RealTime CNC Pendant features a built-in mushroom-style stop button, allowing you to request a machine stop without reaching back to your controller or computer.
Because the pendant is connected by a flexible, coiled cable, you can move around your CNC and keep the stop control close at hand.
The pendant also includes a dedicated enable button to help prevent accidental machine movement while jogging.
These features add another level of convenience and operator control to your CNC workflow.
Note: The pendant's stop button sends a software stop request and is not a replacement for your machine's dedicated hardware stop system.
WORK WHERE YOU NEED TO
One of the biggest advantages of a handheld CNC pendant is being able to stand exactly where you need to be.
Instead of watching your machine from a computer or controller screen, you can position yourself beside your workpiece and watch your cutting tool as you jog.
The rugged, industrial-style enclosure and heavy-duty coiled cable are designed for everyday shop use, while the included storage hook gives your pendant a convenient place to hang when not in use.
PLUG-AND-PLAY WITH REALTIME CNC
The RealTime CNC Pendant Kit is designed to work with any Onefinity CNC running the RealTime control system, including:
Onefinity Gen 2 Elite machines
Onefinity Apprentice
Gen 1 Onefinity machines upgraded to the RealTime Controller
The included USB Pendant Adapter makes connecting easy, whether you're using the Redline 15" HMI or controlling your CNC through a Windows, Mac, or Linux computer.
Simply connect the adapter and pendant, and you're ready to take control with compatible RealTime CNC software.
The pendant is powered directly through USB, so there's no additional power supply required.
KEY FEATURES
100-Pulse High-Resolution Handwheel: Precise optical encoder provides smooth, accurate, tactile jogging.
Three Customizable Movement Scales: Choose 1X, 10X, or 100X increments for coarse or fine positioning.
Multi-Axis Jogging: Select X, Y, Z, and a fourth axis, with two additional assignable selector positions.
Customizable Jog Distances: Configure movement per click or revolution in imperial or metric units.
Built-In Stop Button: Convenient remote software stop request while running a toolpath.
Dedicated Enable Button: Helps prevent unintended machine movement.
Industrial Construction: Rugged handheld enclosure with a heavy-duty coiled cable.
Convenient Storage Hook: Keep your pendant organized and accessible.
USB Powered: No external power supply required.
Plug-and-Play Integration: Pre-wired for compatibility with the RealTime CNC controller ecosystem.
Cross-Platform Compatibility: Supports Windows, Mac, Linux, Redline HMI, and other compatible RTS-X platforms.
WHAT'S INCLUDED
RealTime CNC MPG Pendant
USB Pendant Adapter
USB Cable
Pendant Storage Hook Hardware
COMPATIBILITY
Compatible with:
Onefinity Gen 2 Elite CNC machines
Onefinity Apprentice CNC machines
Onefinity Gen 1 machines upgraded to RealTime
Redline 15" HMI
Windows, Mac, and Linux systems running compatible RTS-X software
Software Requirement: RealTime CNC RTS-X V1.7 or newer.
Not Compatible With: MASSO or Buildbotics controllers.
TAKE CONTROL OF YOUR CNC
Whether you prefer the familiar convenience of a Joypad or the precision of an industrial handwheel, Onefinity gives you the freedom to choose how you control your machine.
The RealTime CNC Pendant Kit delivers accurate, tactile, handheld control that makes machine setup, workpiece positioning, and everyday jogging easier.
More precision. More convenience. More control.
Works With Your Onefinity CNC
The new RealTime Jogging Pendant works with any Onefinity CNC running the RealTime control system, including:
And thanks to the included USB Pendant Adapter, it works whether you're using the Redline 15" HMI or controlling your machine from a Windows PC, Mac, Linux computer, or Raspberry Pi.
No additional power supply is needed. Just plug it in, and you're ready to jog!
Precision Control With a Manual Handwheel
So, what makes this different from our traditional Joypad?
Instead of using joysticks or buttons to move your machine, the RealTime Jogging Pendant features a manual handwheel, also known as an MPG (Manual Pulse Generator).
As you rotate the handwheel, it generates pulses that tell your CNC exactly how far to move.
Each click of the dial produces precise, controlled movement, making it easy to position your machine exactly where you want it.
The pendant features a high-resolution, 100-pulse-per-revolution optical encoder, giving you excellent control over even the smallest movements.
You can select individual axes, including X, Y, Z, and additional axes for supported machine configurations.
You can also choose between three customizable movement scales:
1X: Fine movements for precise positioning
10X: Medium movements for everyday adjustments
100X: Larger movements for quickly positioning your machine
Each scale can be customized with your preferred travel distance per click or revolution, with separate settings for imperial and metric measurements.
This makes the pendant especially useful when:
Positioning your cutting bit
Lining up your workpiece
Setting your X, Y, and Z zero points
Making tiny adjustments during setup
Moving your machine while watching the bit's position
Whether you're making a large positioning move or dialing in a tiny adjustment, you have complete control over how your machine moves.
A Built-In Stop, Right Where You Need It!
And here's another great feature!
The new RealTime Jogging Pendant includes a built-in stop button!
With a traditional controller-mounted Stop, you may need to reach back toward your control system to stop the machine.
With the new pendant, that stop button is right in your hand!
The pendant's cable allows you to move around your CNC while keeping the stop button conveniently within reach.
Whether you're standing at the front of your machine, working along the side, or positioning a workpiece, you can keep the pendant close by.
That means added convenience and easier access to the stop control when you need it.
The pendant also includes a built-in enable button for additional machine-control functionality.
Always follow proper CNC safety procedures and retain your machine's required stop safeguards.
Stand Where You Can See What You're Doing
One of the biggest advantages of a handheld pendant is being able to control your machine from wherever you have the best view.
Instead of looking back and forth between your CNC and a controller screen, you can stand right next to your machine while making precise positioning adjustments.
Watch your bit as you move it.
Fine-tune your position.
Set your zero points.
And make those small corrections without constantly returning to your controller.
It's the familiar feel of a traditional industrial CNC control system, now available for your Onefinity!
More Than Just X, Y, and Z
The RealTime Jogging Pendant isn't limited to basic three-axis jogging.
Its six-position selector includes:
X, Y, Z, 4, 5, and 6.
These positions support additional machine-control functions, including fourth-axis operation and software-assignable controls.
Positions 5 and 6 can be configured through supported software for additional functions such as spindle control or overrides.
Combined with the customizable movement scales, this gives you a flexible control system that can adapt to your CNC workflow.
RealTime Jogging Pendant Features
The Onefinity RealTime MPG Pendant & USB Adapter Kit comes packed with features:
High-resolution manual handwheel: 100-pulse-per-revolution optically encoded MPG for precise machine movement.
Three customizable movement scales: 1X, 10X, and 100X, with adjustable travel-per-click and travel-per-revolution settings.
Imperial and metric support: Configure separate movement values for your preferred measurement system.
Six-position axis selector: X, Y, Z, 4, 5, and 6, with support for additional machine functions.
Built-in stop button: Conveniently located on the pendant for easier access.
Built-in enable button: Additional functionality for machine control.
Plug-and-play connectivity: Pre-wired for compatibility with supported RealTime CNC controllers and software.
Wide operating-system compatibility: Works with Windows, Mac, Linux, Raspberry Pi, and the Redline HMI.
USB powered: No external power supply required.
Convenient storage hook: Keep your pendant organized and within easy reach when not in use.
What's Included?
Everything you need to get started comes in the Onefinity RealTime MPG Pendant & USB Adapter Kit:
Onefinity RealTime Jogging Pendant
USB Pendant Adapter
USB Cable
Another Way to Control Your Onefinity!
Our traditional Xbox-style Joypad isn't going anywhere!
It's still a great way to jog your Onefinity CNC, and plenty of users love its simplicity.
But for those who want the precision, tactile feedback, and familiar feel of a traditional industrial CNC handwheel, the new RealTime Jogging Pendant is an excellent alternative.
With precise movement control, customizable jogging increments, convenient handheld operation, and a built-in stop button, it offers a different way to interact with your machine.
More options. More precision. More control.
And that's what Onefinity is all about!
