Introducing The All New APPRENTICE Series by Onefinity CNC
Updated: Dec 8, 2025
Introducing The All New APPRENTICE Series by Onefinity CNC. The affordable CNC machine perfect for makers just starting out with CNC routers.
Starting at
$995 USD
(for a limited time)
THE APPRENTICE
Robust Construction: Featuring rigid, high-precision, hardened steel linear motion shafts 30mm in diameter, a “Z-16” Z-slider for high speed carves and thick aerospace grade aluminum gantry blocks and rail ends for the ultimate in ruggedness.
Advanced Motion Control: Equipped with powerful stepper motors, and 16mm diameter precision ball screws ensuring quick, smooth and accurate movements and a 350 watt power supply ensuring ample power is available.
Best in class warranty: The Apprentice comes with a “best in class” two (2) year warranty on all mechanical components.
Quality Control: Before shipping, each machine undergoes a comprehensive inspection and hands-on testing—including a test carve—to ensure it meets our highest standards of quality and performance.
The Apprentice combines advanced technology with user-centric design, making it a reliable choice for professionals and hobbyists alike.
THE APPRENTICE FEATURES:
Cutting edge, custom designed, REDLINE Control System
Full 2D & 3D Carve Simulation (No wire frames)
Step-by-step how-to animations
16mm diameter, fast travel, precision ball screws on each axis
30mm diameter, hardened steel linear shaft for great rigidity
Revolutionary “gap-free,” snap in ball screw covers dramatically reducing maintenance
Industry leading “2 Year Warranty”
High speed, Gen 2 Z-16 Z-Slider
Powerful 1.2Nm stepper motors
Stall homing with auto squaring
350 Watt power supply for great speed and torque
Plug and Play wiring supported by drag chains
Best-in-class plug and play REDLINE spindle with on board controls (optional)
Plug and play XYZ probe (optional)
Plug and play tool setter (optional)
65mm Suckit SM Dust Boot (optional)
Continuous and incremental jogging via touch screen
Feed rate and spindle speed override - Adjust feed rate and spindle RPMs during a carve
Multiple work offsets (G54-G59)
Quick and easy setup - start carving in under an hour
User friendly design
7, 14 and 64 watt laser (optional—plug and play)
Each unit is fully production tested with a test carve to ensure proper functionality and quality
A large “how to” library with a helpful and supportive community
Powerful Carveco Maker advanced 3D CAD software (1 year subscription)
And much more…
SOLID. RIGID. BEEFY. PRECISE.
With rails comprised of high-precision, hardened steel, linear motion shafts 30mm in diameter, precision machined gantry blocks and rail ends, both made from aerospace grade aluminum, sealed, high load, linear bearings. The heavy-duty Z-Slider is composed of 5/8” thick aluminum plates and 16mm hardened steel, linear motion shafts making the Apprentice rock solid!
PRECISE. DURABLE. SIMPLE.
Each axis comes standard with quality 16mm ball screws for the utmost precision and speed. Revolutionary snap-in ball screw covers and sealed, high load, round linear bearings to ensure smooth, low maintenance motion. Powerful, 1.2Nm stepper motors for accurate, risk-free carves. A 350 watt power supply to ensure there’s plenty of power available. Advanced Redline controller for smart, intuitive and reliable motion control. Assembly time is minimal with many of our customers up and carving in less than one hour!
TORQUE.
The Apprentice comes standard with a 350 watt power supply and 1.2Nm motors giving you enough torque to rip through carves at high speeds
RIGIDITY.
The Apprentice comes equipped with 30mm hardened steel linear shafts making it one of the most rigid machines its class.
ACCELLERATION.
The Apprentice is capable of high accelerations, however, if you’re new to CNC machining, high accelerations rates can increase the risk of breaking bits or ruining your workpiece.
Because we want your Onefinity experience to be smooth and enjoyable from the onset, we’ve set the default acceleration to a level that better protects both your expensive bits and material. Once you’re comfortable with the machine and your carving techniques, feel free to push those limits. Don’t worry about breaking the Apprentice, we've already tried... unsuccessfully. It will be ready when you are!
REVOLUTIONARY, GAP-FREE, SNAP-IN BALL SCREW COVERS.
The Apprentice takes low maintenance to the next level. Featuring our revolutionary, patent-pending “gap-free” ball screw covers, this machine is built to keep you running without interruptions.
Forget stopping production to clean your machine. Forget jams, binding, or downtime from lack of upkeep. The Apprentice is designed to power through long runs while keeping your rails and ball screws protected.
Onefinity has always been loved for how little maintenance it needs. Our round rails naturally let dust roll right off, and the sealed linear bearings keep things clean and running smoothly.
CUTTING AREA.
The Apprentice features a cutting area of 16-1/2”” along the X-Axis and 16-1/2” along the Y-Axis.
LARGE GANTRY CLEARANCE.
With 5-1/4” of gantry clearance, The Apprentice has the highest gantry clearance in its class. Having more gantry clearance is useful when you need to use fixtures or jigs to hold your parts or when you want to use thicker material.
ADVANCED REDLINE CONTROLLER FEATURES:
Fully 3D (no wire frames) tool path display so you can see your carve in real time
No USB disconnects. Files download to the controller ensure a smooth, successful carve
Automatic G-Code scan — Determine issues prior to run. (e.g. limit extents/invalid commands)
Preloaded bit diameters to save time while probing. No typing necessary.
Plug & Play joypad for quick and easy jogging (optional)
Increase or decrease spindle speed while running
Ability to save coordinates
Simple, easy-to-use screen layout
Jog while paused
Continuous & incremental jogging via touch screen
Feed Rate Override - Adjust feed rate during a carve
And much more...
STEP-BY-STEP HOW-TO ANIMATIONS!
Most CNC controllers are functional—but flat. Endless numbers. Dry screens. They get the job done, but they don’t inspire. The REDLINE Controller changes everything.
With fluid animations and real-time visual feedback, everyday CNC work becomes a seamless, almost cinematic experience.
Routine tasks come alive, guided by motion and visuals that feel effortless.
New users are welcomed intuitively, learning through experience instead of spreadsheets.
Seasoned makers gain precision and speed, interacting with a sleek, modern interface designed to feel as natural as it is powerful.
This isn’t just a controller — it’s a leap forward in how you interact with the Onefinity. Numbers still run in the background, but your eyes enjoy a clear, visual, and modern experience that feels as powerful as it is fun.
Step into the future of CNC with the REDLINE Controller, and experience the animations that bring every operation to life.
Here’s a glimpse of the stunning animations that bring the REDLINE CNC Controller to life
DIMENSIONS.
Below are the external dimensions of the Apprentice. These dimensions will help you build a base and/or select an appropriate table. You can also use the shown dimensions to create a waste board.
BALL SCREWS ON EACH AXIS
The Onefinity Apprentice is built on 1610 ball screws, delivering exceptional precision, rigidity, and speed. Unlike machines that rely on rubber belts or lead screws—which wear out, stretch, and require constant tweaking—the Apprentice’s ball screws are virtually maintenance-free. A light oiling now and then is all it takes to keep everything running smoothly.
SPEED, POWER. AND DURABILITY.
The Apprentice Z-16 (Z-Slider) is powerful, rigid and speedy. Offering great speed, torque and precision due to the 12mm ball screw and powerful 1.2Nm stepper motor. Along with a large range of motion, the Z-16 is a solid Z-slider with great performance.
Apprentice Z-Slider Features:
1.2Nm stepper motor
Large 16mm hardened steel linear shafts maximizing rigidity
Slim design for added X-axis travel
Sealed, high-load, linear bearings
12mm ball screw for precision, speed and rigidity
5 1/4” of total travel distance
Provisions for mounting a laser and other accessories
Thick precision machined back plates
And more...
INDUSTRY LEADING QUICK SETUP.
Keeping true to what customers love about the Onefinity CNC, the Apprentice can be assembled very quickly. Everything is plug and play and only 12 bolts are required to assemble the Onefinity (8 bolts to fasten the X-Axis to the Y-Axis and 4 to attach the Z-20 (Z-slider). Once your machine is fastened together, just mount your display and screw the Y-Axis to your table or QCW. Most customers are carving in less than an hour!
REDLINE SAFETY APPROVED SPINDLE (65mm optional)
Increase the power and performance of the Apprentice by purchasing a 65mm REDLINE Spindle. REDLINE Spindles are the only safety approved plug and play spindles on the market. The REDLINE Spindle Kits are of the highest quality and feature an all metal VFD enclosure (no plastic or 3D printed parts) along with properly grounded and shielded wires and cables. The REDLINE Spindle Kits ensure all power lines are properly filtered and the spindles feature four ceramic bearings
7, 14 and 64 WATT LASER (OPTIONAL)
The Onefinity CNC offers you the ability to quickly add a quality J-Tech laser that is completely plug and play. Many of our customers create mind blowing carves using their Onefinity CNC, but if you really want to set yourself apart from the crowd, add some “freakin’ laser beams.”
EACH UNIT FULLY INSPECTED
Onefinity’s quick and easy set up allows us to do something no other company can; Each machine is fully assembled, thoroughly inspected and tested, which includes performing an actual test carve. Your machine is then packaged for shipping along with the test carved “Team Onefinity” sign. No other CNC company can ensure your machine is at its highest quality before leaving the factory. They may test parts of the machine, but don’t be fooled, they don’t test the full machine.
PLUG AND PLAY TOOL SETTER AND XYZ TOUCH PROBE
The Apprentice Tool Setter is a semi-automatic tool offset probe that makes it easy to run jobs using multiple tools without the need to stop and re-zero manually. The XYZ Probe allows you to quickly and precisely zero your CNC's X, Y, and Z axis.
A LARGE HOW-TO LIBRARY WITH A HELPFUL AND SUPPORTIVE COMMUNITY
The Onefinity community prides itself on being supportive, helpful, and includes a wealth of resources including how-to videos and informative blogs. With knowledgeable community members and administrators, you will have access to many helpful creators and makers at all hours of the day and night. Onefinity has over 100,000 members across our forums, Facebook group, Instagram and YouTube channels. Watch a number of exciting educational series such as Morgan Hop’s “Onefinity University,” Kyle Ely’s “Learn your CNC” and Two Moose Design’s “5 Projects to Make and Sell” along with many others. You will find an abundance of resources and help to ensure you are successful and productive with your Onefinity.
POWERFUL 3D CAD/CAM SOFTWARE INCLUDED
The Apprentice include a 1-year subscription to the full-featured 3D design and machining program Carveco Maker.
Featuring easy-to-use design tools and the ability to create highly accurate, dependable toolpaths, Carveco Maker is a powerful CAD/CAM program providing you the ability to create virtually anything you imagine.
Whether you’re a weekend maker, traditional craftsman, or brand new to working with a CNC router, Carveco Maker provides you with all the tools you need to create high-quality 2D and 3D products quickly and easily.
Already have CAD/CAM software you like? No problem! The Onefinity accepts standard G-code, so you can use your preferred software.
LETE WITH A
TEST CARVE
Orders for the Apprentice will start on November 25, 2025 at 11am Eastern. To see videos, learn more, and place your order, head over to the Onefinity CNC website at onefinitycnc.com
ONEFINITY APPRENTICE
Starting at
$995 USD
COMPL
General Disclaimer: While Onefinity has made every effort at the time of publication to ensure the accuracy of the information provided herein, product specifications, configurations, system/component/options availability are all subject to change without notice. Product design specifications and colours are subject to change without notice and may vary from those shown. Errors and omissions excepted. Images displayed are for illustration purposes only. The images are intended to help illustrate the product and it’s functions and are not indicative of actual relative differences.
